Hi! I'm getting ready to LE release in november, so started to play arround with the client.
The FAQ states:
Can I use an existing private key or Certificate Signing Request (CSR) with the Let's Encrypt client?
Yes, you can obtain a certificate for an existing private key (if the
key is an appropriate type and size), and, if you want, you can use an
existing CSR.
How should I tell LE client to use my old good CSR from my server?
Hi @razor7! Currently, to use a preexisting CSR, the CSR has to be in DER format and have subject alternative names for every domain you wish to receive a cert for. If you have this, include the --csr option on the command line with the path to the CSR you’d like to use and run the auth command like so:
letsencrypt --csr /path/to/csr auth
You can include any other additional flags that you wish, such as --cert-path which specifies where to save the resulting certificate (if it’s not included, it’s saved in your working directory).
The auth command obtains a certificate from the ACME server but does not install it to your webserver. You can install it afterwards using the install command.
@skunkwerk and @nilesh, perhaps you have a CSR in DER format instead of PEM format?
If you run openssl req -in ~/mydomain.csr -text -noout, do you see data from the CSR? If not, do you see data by running openssl req -inform der -in ~/mydomain.csr -text -noout?
In this case, you need to convert the CSR to PEM format via
openssl req -inform der -outform pem -in ~/mydomain.csr -out ~/mydomain.pem
or something similar. The Let’s Encrypt client is expecting the CSR to be in PEM format, not DER format.
