mydomain.ddns.net
certbot -d mydomain.ddns.net
An unexpected error occurred:
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe9 in position 2272: invalid continuation byte
nginx/1.20.0
php7.3-fpm
Debian 10 x64
myself but need to choice a provider soon
no
certbot 0.31.0
letsencrypt.log:
2021-05-05 08:26:26,624:DEBUG:certbot.log:Exiting abnormally:
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1365, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1101, in run
installer, authenticator = plug_sel.choose_configurator_plugins(config, plugins, "run")
File "/usr/lib/python3/dist-packages/certbot/plugins/selection.py", line 225, in choose_configurator_plugins
authenticator = installer = pick_configurator(config, req_inst, plugins)
File "/usr/lib/python3/dist-packages/certbot/plugins/selection.py", line 25, in pick_configurator
(interfaces.IAuthenticator, interfaces.IInstaller))
File "/usr/lib/python3/dist-packages/certbot/plugins/selection.py", line 106, in pick_plugin
verified.prepare()
File "/usr/lib/python3/dist-packages/certbot/plugins/disco.py", line 251, in prepare
return [plugin_ep.prepare() for plugin_ep in six.itervalues(self._plugins)]
File "/usr/lib/python3/dist-packages/certbot/plugins/disco.py", line 132, in prepare
self._initialized.prepare()
File "/usr/lib/python3/dist-packages/certbot_nginx/configurator.py", line 152, in prepare
self.parser = parser.NginxParser(self.conf('server-root'))
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 38, in init
self.load()
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 45, in load
self._parse_recursively(self.config_root)
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 66, in _parse_recursively
self._parse_recursively(subentry[1])
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 56, in _parse_recursively
trees = self._parse_files(filepath)
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 207, in _parse_files
parsed = nginxparser.load(_file)
File "/usr/lib/python3/dist-packages/certbot_nginx/nginxparser.py", line 123, in load
return loads(_file.read())
File "/usr/lib/python3.7/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
other debug:
grep -RP '[^\x00-\x7f]' /etc/nginx/ => return nothing
grep -RP '[^\x00-\x7f]' /etc/letsencrypt/ => return nothing
I don't know what happen, for my first subdomain, it work perfectly and now, i'l get his error...
and it work now
