hi there,
ubuntu server 18.04
i tried this command :
sudo certbot --expand -d abc.toto.com
i get this error :
An unexpected error occurred:
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe0 in position 6097: invalid continuation byte
here is the log file :
2022-06-28 18:17:09,199:ERROR:certbot.log:An unexpected error occurred:
2022-06-28 18:18:22,825:DEBUG:certbot.main:certbot version: 0.31.0
2022-06-28 18:18:22,826:DEBUG:certbot.main:Arguments: ['--expand', '-d', 'abc.toto.com']
2022-06-28 18:18:22,826:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-06-28 18:18:22,834:DEBUG:certbot.log:Root logging level set at 20
2022-06-28 18:18:22,835:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-06-28 18:18:22,836:DEBUG:certbot.plugins.selection:Requested authenticator None and installer None
2022-06-28 18:18:22,856:DEBUG:certbot.log:Exiting abnormally:
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1365, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1101, in run
installer, authenticator = plug_sel.choose_configurator_plugins(config, plugins, "run")
File "/usr/lib/python3/dist-packages/certbot/plugins/selection.py", line 225, in choose_configurator_plugins
authenticator = installer = pick_configurator(config, req_inst, plugins)
File "/usr/lib/python3/dist-packages/certbot/plugins/selection.py", line 25, in pick_configurator
(interfaces.IAuthenticator, interfaces.IInstaller))
File "/usr/lib/python3/dist-packages/certbot/plugins/selection.py", line 106, in pick_plugin
verified.prepare()
File "/usr/lib/python3/dist-packages/certbot/plugins/disco.py", line 251, in prepare
return [plugin_ep.prepare() for plugin_ep in six.itervalues(self._plugins)]
File "/usr/lib/python3/dist-packages/certbot/plugins/disco.py", line 132, in prepare
self._initialized.prepare()
File "/usr/lib/python3/dist-packages/certbot_nginx/configurator.py", line 152, in prepare
self.parser = parser.NginxParser(self.conf('server-root'))
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 38, in init
self.load()
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 45, in load
self._parse_recursively(self.config_root)
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 56, in _parse_recursively
trees = self._parse_files(filepath)
File "/usr/lib/python3/dist-packages/certbot_nginx/parser.py", line 207, in _parse_files
parsed = nginxparser.load(_file)
File "/usr/lib/python3/dist-packages/certbot_nginx/nginxparser.py", line 123, in load
return loads(_file.read())
File "/usr/lib/python3.6/codecs.py", line 321, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
2022-06-28 18:18:22,858:ERROR:certbot.log:An unexpected error occurred:
i have read many things, but no way to really solve this problem and use certbot..
if one of you have the solution.. it would be very nice to share it..
