Certbot --nginx error : UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe9 in position 436: invalid continuation byte
Hello
I am a beginner with let's encrypt, and just install on my server. But I got this error about utf8
"UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe9 in position 436: invalid continuation byte"
Extract from /var/log/letsencrypt/letsencrypt.log
An unexpected error occurred:
My domain is: archeos.cdg44.fr
I ran this command: certbot --nginx -d archeos.cdg44.fr
My web server is (include version): debian10
The operating system my web server runs on is (include version): nginx 1.14.2
My hosting provider, if applicable, is: me
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
Thanks for your help
try manually use certonly and webroot authinator so it doesn't try to parse nginx config
ps: I'm going to sleep
Ok, thank you for your answer...but I really don't know how to do this ^^
So, the problem is that your nginx config has some bytes in it which aren't valid UTF-8 characters. This may not be causing other problems, but it's certainly weird and is preventing certbot from understanding your config. So, you should probably find that byte, figure out what the configuration there should be, and fix it.
If you can't do that, then there are other ways to configure certbot, where instead of it trying to update your nginx configuration, you can tell it a "webroot" to place a file, where nginx is already configured to serve those files.
Thank you for your answer.
Do You mean the Vhost config ?
I'm not particularly familiar with nginx configuration myself (though many other people here are), but I'm guessing it's whichever file has "byte 0xe9 in position 436" and probably shouldn't.
Yes, I get it, but I don't kwno which file is concerned ....
An nginx forum or its own docs are best places to learn about nginx. And, nginx can be installed in non-standard places. But, your initial conf file is probably here:
/etc/nginx/nginx.conf
That conf file probably includes other folders with conf files so you can follow those manually.
Normally you can see the whole nginx config with: sudo nginx -T
(uppercase T)
But, this may not work when there are errors in the config
In this case it looks like the character may be an accented e
Still, see the Certbot docs for instructions on using --webroot method. That may be needed in your case instead of --nginx method.
And, your Certbot version (and nginx version) are very old. Debian 10 is also now end of life. Updating at least Certbot may help.
This is actually the core of the problem.
Older versions of Certbot had a series of bugs where they would not work properly with foreign-language characters (like àèìòùäëïöü etc.), which might be mentioned in configuration files especially in comments like
# Esse é um comentário em português
# Ceci est un commentaire en français
All of these bugs were fixed in newer versions of Certbot over the past few years, but some people are still using very old versions of Certbot. Version 0.31.0 is a very old version.
Using such an old version usually means that you installed it from an operating system package that's not being kept up to date by the operating system maintainers (which is common on Debian, unfortunately!). If you check
you can find recommended installation methods for different operating systems, which, if followed, will get you a newer version of Certbot which shouldn't have this bug.
Yes, it's also a very good idea in general to get an operating system and other software that are receiving updates!
I didn't realize this, but the recommended Certbot installation methods for all Linux distributions are now down to just snap and pip!
Yes, their site was changed recently. Caught us all by surprise.
Each main install page still has the link for "Alternate" methods here ... Docker, pip, 3rd Party.
https://eff-certbot.readthedocs.io/en/latest/install.html
Presumably 3rd party includes the standard distro provided packaging system
Yes I've already checked my nginx.conf file, I didn't find any é neitheir in the VHost file.
So I supposed I need to upgrade my debian10 to bookworm...
Thank you for yor help
