UnicodeDecodeError: 'utf-8' codec can't decode byte 0x96 in position 1302: invalid start byte
My domain is: fastcloud.co.za
sudo certbot --nginx
An unexpected error occurred:
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0x96 in position 1302: invalid start byte
Copy from logfile:
2020-05-31 15:22:30,074:DEBUG:certbot.main:certbot version: 0.31.0
2020-05-31 15:22:30,075:DEBUG:certbot.main:Arguments: [’–nginx’]
2020-05-31 15:22:30,076:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-05-31 15:22:30,088:DEBUG:certbot.log:Root logging level set at 20
2020-05-31 15:22:30,089:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-05-31 15:22:30,089:DEBUG:certbot.plugins.selection:Requested authenticator nginx and installer nginx
2020-05-31 15:22:30,107:DEBUG:certbot.log:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==0.31.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1365, in main
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1101, in run
installer, authenticator = plug_sel.choose_configurator_plugins(config, plugins, “run”)
File “/usr/lib/python3/dist-packages/certbot/plugins/selection.py”, line 225, in choose_configurator_plugins
authenticator = installer = pick_configurator(config, req_inst, plugins)
File “/usr/lib/python3/dist-packages/certbot/plugins/selection.py”, line 25, in pick_configurator
(interfaces.IAuthenticator, interfaces.IInstaller))
File “/usr/lib/python3/dist-packages/certbot/plugins/selection.py”, line 106, in pick_plugin
verified.prepare()
File “/usr/lib/python3/dist-packages/certbot/plugins/disco.py”, line 251, in prepare
return [plugin_ep.prepare() for plugin_ep in six.itervalues(self._plugins)]
File “/usr/lib/python3/dist-packages/certbot/plugins/disco.py”, line 132, in prepare
self._initialized.prepare()
File “/usr/lib/python3/dist-packages/certbot_nginx/configurator.py”, line 152, in prepare
self.parser = parser.NginxParser(self.conf(‘server-root’))
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 38, in init
self.load()
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 45, in load
self._parse_recursively(self.config_root)
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 56, in _parse_recursively
trees = self._parse_files(filepath)
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 207, in _parse_files
parsed = nginxparser.load(_file)
File “/usr/lib/python3/dist-packages/certbot_nginx/nginxparser.py”, line 123, in load
return loads(_file.read())
File “/usr/lib/python3.6/codecs.py”, line 321, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
2020-05-31 15:22:30,109:ERROR:certbot.log:An unexpected error occurred:
nginx/1.14.0 (Ubuntu)
Description: Ubuntu 18.04.2 LTS
Release: 18.04
Codename: bionic
Self
Yes
No
certbot 0.31.0
Hi @FASTCLOUD
check your nginx config files if there is a non-Ascii character.
May be the ` (GRAVE ACCENT) or another character, that's codepage specific.
A way to locate the line it’s on might make it easier for you:
grep -RP "\x96" /etc/nginx/
The Unicode problems with the nginx plugin were fixed in 1.4.0, but that release is not available in the Ubuntu PPA.
