Hello, this is my first post. Certbot has run flawlessly until now.
kph.x.dittweb.no
certbot --authenticator webroot --webroot-path /var/www/sites/k/kiropraktikk-helse.no/www_20/ --installer nginx -d kph.x.dittweb.no --debu
Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==0.31.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1365, in main
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1101, in run
installer, authenticator = plug_sel.choose_configurator_plugins(config, plugins, “run”)
File “/usr/lib/python3/dist-packages/certbot/plugins/selection.py”, line 228, in choose_configurator_plugins
installer = pick_installer(config, req_inst, plugins, installer_question)
File “/usr/lib/python3/dist-packages/certbot/plugins/selection.py”, line 32, in pick_installer
config, default, plugins, question, (interfaces.IInstaller,))
File “/usr/lib/python3/dist-packages/certbot/plugins/selection.py”, line 106, in pick_plugin
verified.prepare()
File “/usr/lib/python3/dist-packages/certbot/plugins/disco.py”, line 251, in prepare
return [plugin_ep.prepare() for plugin_ep in six.itervalues(self._plugins)]
File “/usr/lib/python3/dist-packages/certbot/plugins/disco.py”, line 132, in prepare
self._initialized.prepare()
File “/usr/lib/python3/dist-packages/certbot_nginx/configurator.py”, line 152, in prepare
self.parser = parser.NginxParser(self.conf(‘server-root’))
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 38, in init
self.load()
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 45, in load
self._parse_recursively(self.config_root)
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 66, in _parse_recursively
self._parse_recursively(subentry[1])
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 56, in _parse_recursively
trees = self._parse_files(filepath)
File “/usr/lib/python3/dist-packages/certbot_nginx/parser.py”, line 207, in _parse_files
parsed = nginxparser.load(_file)
File “/usr/lib/python3/dist-packages/certbot_nginx/nginxparser.py”, line 123, in load
return loads(_file.read())
File “/usr/lib/python3.5/codecs.py”, line 321, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0x93 in position 672: invalid start byte
nginx/1.10.3 (Ubuntu)
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
no
certbot 0.31.0
