i got same issue
Welcome @debraplm51
Many times the problem looks the same but usually has different fix. You originally posted on another thread which has now been solved. If you had the exact same problem you can find the fix for that here.
If that does not fix your problem, please answer the questions below the best you can. You would have been shown these if you had posted a new problem to start. Thank you
