Unable to do my first certificate renewal using certbot
My domain is: topoi.pooq.com
I ran this command: cron runs certbot for me, automatically.
Date: Tue, 16 Apr 2024 10:20:46 -0400 (EDT)
To: root@topoi.pooq.com
Subject: Cron root@notlookedfor test -x /usr/bin/certbot -a ! -d /run/systemd/system && perl -e 'sleep
int(rand(43200))' && certbot -q renew
Failed to renew certificate topoi.pooq.com with error: Problem binding to port 80: Could not bind to IPv4 or IPv6.
/etc/letsencrypt/live/topoi.pooq.com/fullchain.pem (failure)
The operating system my web server runs on is (include version): Linux Devuan chimaera
My hosting provider, if applicable, is: myself, on the very machine I'm having trouble on.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.12.0
I have no difficulty reaching port 80 of the server from another machine, either inside or outside my LAN.
Let's debug informs me:
All OK!
OK
No issues were found with topoi.pooq.com. If you are having problems with creating an SSL certificate, please visit the Let's Encrypt Community forums and post a question there.
-- hendrik
Hello @hendrikboom3, welcome to the Let's Encrypt community. :slightly_smiling_face:
More just supplemental information.
This is the web server Server: lighttpd/1.4.59
$ curl -Ii http://topoi.pooq.com/.well-known/acme-challenge/sometestfile
HTTP/1.1 404 Not Found
Content-Type: text/html
Content-Length: 341
Date: Sat, 20 Apr 2024 02:03:52 GMT
FYI - Port 443 is filtered
$ nmap -Pn -p80,443 topoi.pooq.com
Starting Nmap 7.80 ( https://nmap.org ) at 2024-04-20 02:04 UTC
Nmap scan report for topoi.pooq.com (69.165.131.134)
Host is up (0.96s latency).
PORT    STATE    SERVICE
80/tcp  open     http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 2.17 seconds
Please show the renewal config file:
/etc/letsencrypt/renewal/topoi.pooq.com.conf ?
I believe this is the same as it was when I registered my site months ago.
hendrik@notlookedfor:~$ cat /etc/letsencrypt/renewal/topoi.pooq.com.conf
version = 1.12.0
archive_dir = /etc/letsencrypt/archive/topoi.pooq.com
cert = /etc/letsencrypt/live/topoi.pooq.com/cert.pem
privkey = /etc/letsencrypt/live/topoi.pooq.com/privkey.pem
chain = /etc/letsencrypt/live/topoi.pooq.com/chain.pem
fullchain = /etc/letsencrypt/live/topoi.pooq.com/fullchain.pem
[renewalparams]
account = fe85acd10dd3633fbeb66be44f8afb5e
authenticator = standalone
The standalone method requires exclusive use of port 80. When you first got your cert no other service was using that port so it worked.
But, now your lighttpd server is using that port.
You need to stop lighttpd before renewal and start it after. Ideally using Certbot's pre-hook and post-hook options.
Or, change to the webroot method and use the active lighttpd to respond to the challenge.
Either method requires running Certbot using a different set of options to reset the renewal profile.
Let us know if you need help re-running Certbot. And, if so, which method you want to use (stopping/starting lighttpd or using webroot).
Stoppoing and restarting lightppd did the trick. Thank you.
