Type: unauthorized Detail: Invalid response from
i-peek.eu and many others.
sudo certbot renew
Domain: i-peek.eu
https://i-peek.eu/.well-known/acme-challenge/VF1gEWJdM-dsnhotGJr-E4CX0Q7hOnUsNbGyjm3_-oA
[46.137.96.254]: “\n\n404 Not
Found\n\n
Not Found
\n<p”
Server version: Apache/2.4.29 (Ubuntu)
Linux ip-172-30-0-219 4.15.0-1039-aws #41-Ubuntu SMP Wed May 8 10:43:54 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
running on AWS
no
certbot 0.23.0
running journalctl -u certbot.service gives no problems till May 26th. Then:
/etc/letsencrypt/renewal/www.i-peek.eu.conf produced an unexpected error: Failed authorization procedure. i-peek.nl (http-01): urn:acme:error:unauthorized :: …
Tried all fixes available on this forum:
Remarks:
  • Ubuntu upgraded Certbot to use systemd. Before(?) that it worked fine. Questionmark!
  • 12 domainname give an error and 1 not, but they have the same configuration except the name and webroot. So it should be the configuration, not the software.
  • All sites use headers like:
    Header always set Strict-Transport-Security “max-age=63072000; includeSubdomains; preload”
  • We allow only TLS 1.2.
And now we are lost. Thanks is advance for pointing us in the right direction.
Hi @arjenmeijer
checking your main configuration that looks good ( https://check-your-website.server-daten.de/?q=i-peek.eu ):
http://i-peek.eu/
46.137.96.254 301 https://i-peek.eu/ 0.070 A
http://www.i-peek.eu/
46.137.96.254 301 https://www.i-peek.eu/ 0.073 A
https://i-peek.eu/
46.137.96.254 200 0.810 A
46.137.96.254 200 0.440 A
geregistreerd via Argeweb
46.137.96.254 301 https://i-peek.eu/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.076 A
Visible Content: Moved Permanently The document has moved here . Apache/2.4.29 (Ubuntu) Server at i-peek.eu Port 80
46.137.96.254 301 https://www.i-peek.eu/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.074 A
Visible Content: Moved Permanently The document has moved here . Apache/2.4.29 (Ubuntu) Server at www.i-peek.eu Port 80
https://i-peek.eu/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 404 0.553 A
Not Found
Visible Content: Not Found The requested URL /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de was not found on this server. Apache/2.4.29 (Ubuntu) Server at i-peek.eu Port 443
https://www.i-peek.eu/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 404 0.453 A
Not Found
Visible Content: Not Found The requested URL /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de was not found on this server. Apache/2.4.29 (Ubuntu) Server at www.i-peek.eu Port 443
Port 80 is open and answers correct. You have a lot of older certificates, first from 2016-02-15 11:41:00. Looks like you have used tls-sni-01 validation, that's not longer supported (end ~~ 2019-03-15). So you have to use another validation method.
That's
wonderful. So use this information:
certbot run -a webroot -i apache -w yourWebroot -d i-peek.eu
Thank you! Running the command
certbot run -a webroot -i apache -w yourWebroot -d i-peek.eu gives
Congratulations! You have successfully enabled https://i-peek.eu.
However, if I open the site https://i-peek.eu the old certificate is shown. A caching problem? Do I manually have to restart Apache? Does certbot this automatically?
My second question is how I can use another validation method permanently use the weekly certbot run? Do I have to change a configuration file somewhere to a new protocol?
And the third question is how to remove all old certificates at once? Is a command available?
Looks like you have an orphaned process.
Checked via https://check-your-website.server-daten.de/?q=i-peek.eu there are two certificates listed:
The old:
CN=i-peek.nl
	24.03.2019
	22.06.2019
expires in 19 days	i-peek.eu, i-peek.nl,
www.i-peek.eu, www.i-peek.nl - 4 entries
The new:
CN=i-peek.eu
	03.06.2019
	01.09.2019
expires in 90 days	i-peek.eu, i-peek.nl,
Checked the non-www version with Chrome, first I saw the new, then the old certificate. Now I see the new again.
You should reboot your server to see, if it is a temporary or a permanent problem. That happens sometimes if there are two processes, one with the old, one with the new certificate.
Rebooted, but the ‘old’ certificate comes up in a browser. Fixed by reloading the page. Now the certificated is shown correctly.
Log after reboot:
systemd-crontab-generator[365]: ignoring /etc/cron.d/certbot because native timer is present
Started Run certbot once a week.
Remains the question how to change the protocol of certbot to the latest one.
Now it looks ok - https://check-your-website.server-daten.de/?q=i-peek.nl
Only the new certificate is listed
CN=i-peek.eu
	03.06.2019
	01.09.2019
expires in 89 days	i-peek.eu, i-peek.nl,
Both connections use that certificate.
I don't understand your question.
You have two active certificates
CertSpotter-Id Issuer not before not after Domain names LE-Duplicate next LE
947369927 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-03 18:25:14 2019-09-01 18:25:14 i-peek.eu, i-peek.nl, www.i-peek.eu, www.i-peek.nl - 4 entries duplicate nr. 1
826878605 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-03-24 01:04:39 2019-06-22 01:04:39 i-peek.eu, i-peek.nl, www.i-peek.eu, www.i-peek.nl - 4 entries
both have the same set of domain names. So Certbot should only renew the latest.
What says
certbot certificates
Well, the problems started with the weekly run of Certbot, using an old protocol. I updated the certificates by hand. I didn’t change anything in the configuration. So next time, Certbot will use the old protocol again and give problems? Or, was the problem caused to running two processes and are problems fixed by rebooting?
That updated the config file. So next time, the new settings are used.
Check your config file in
There you should see your used webroot-method and your used webroot.
Thank you for the explanation!
