Error: unauthorized / Detail: Invalid response from
My domain is: myhuntingboardserver.com
I ran this command: sudo docker-compose logs certbot
certbot | Saving debug log to /var/log/letsencrypt/letsencrypt.log
certbot | Plugins selected: Authenticator webroot, Installer None
certbot | Obtaining a new certificate
certbot | Performing the following challenges:
certbot | http-01 challenge for myhuntingboardserver.com
certbot | http-01 challenge for www.myhuntingboardserver.com
certbot | Using the webroot path /var/www/html for all unmatched domains.
certbot | Waiting for verification…
certbot | Challenge failed for domain myhuntingboardserver.com
certbot | Challenge failed for domain www.myhuntingboardserver.com
certbot | Cleaning up challenges
certbot | Some challenges have failed.
certbot | IMPORTANT NOTES:
certbot | - The following errors were reported by the server:
certbot |
certbot | Domain: myhuntingboardserver.com
certbot | Type: unauthorized
certbot | Detail: Invalid response from
certbot | http://myhuntingboardserver.com/.well-known/acme-challenge/JZRV9u47V5NohVnY8K6HEeRh7xnMXcAZtx-Zk5tukkY
certbot | [188.165.33.122]: “\r\n404 Not
certbot | Found\r\n<body bgcolor=“white”>\r\n
404
certbot | Not Found
\r\n
certbot |
certbot | Domain: www.myhuntingboardserver.com
certbot | http://www.myhuntingboardserver.com/.well-known/acme-challenge/3QV5vyJ15ceqChYpfVNjuAhbLwO8V_X3cRbKJ6CPrhA
404
certbot | Not Found
\r\n
certbot |
certbot | To fix these errors, please make sure that your domain name was
certbot | entered correctly and the DNS A/AAAA record(s) for that domain
certbot | contain(s) the right IP address.
I use docker-compose.yml :
services:
nodejs:
build:
context: .
dockerfile: Dockerfile
image: nodejs
container_name: nodejs
restart: unless-stopped
networks:
- app-network
webserver:
image: nginx:mainline-alpine
container_name: webserver
ports:
- “8084:80”
volumes:
- web-root:/var/www/html
- ./nginx-conf:/etc/nginx/conf.d
- certbot-etc:/etc/letsencrypt
- certbot-var:/var/lib/letsencrypt
depends_on:
- nodejs
networks:
- app-network
certbot:
image: certbot/certbot
container_name: certbot
volumes:
depends_on:
- webserver
command: certonly --webroot --webroot-path=/var/www/html --email edouarddelaage@gmail.com --agree-tos --no-eff-email --staging -d myhuntingboardserver.com -d www.myhuntingboardserver.com
volumes:
certbot-etc:
certbot-var:
web-root:
driver: local
driver_opts:
type: none
device: /www/node_project/views/
o: bind
networks:
app-network:
driver: bridge
listen 188.165.33.122:80;
listen [::]:80;
root /var/www/html;
index index.html index.html index.nginx-debian.html;
    server_name myhuntingboardserver.com www.myhuntingboardserver.com;
            proxy_pass http://nodejs:8080;
    location ~ /.well-known/acme-challenge {
            allow all;
            root /var/www/html;
My hosting provider, if applicable, is: ovh
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
You might want to remove your email address (seen above).
And also place a test text file in the webroot folder to see if it can be accessed directly from the Internet.
Thanks for your response rg305,
Why remove email address ?
And where is webroot folder? in my /var/www/html i juste have a file : index.nginx.debian.html
So you don't risk getting any SPAM to it.
Seeing your email address here, or not, changes nothing with your request for help in this community.
Looks like it is:
