TSOhost problem help
My domain is: https://gardensuburblibrary.org.uk/gscl/
I ran this command: N/A
It produced this output: N/A
My hosting provider, if applicable, is: Tsohost - Tsohost "We have noticed an issue with Let's Encrypt on our Cloud hosting platform" this has been an issue since 23rd Oct and we can't renew our SSL certificate through Tsohost - is it possible to renew it elsewhere ?
Hi and welcome to the community!
I'm sorry to hear about your expired cert :frowning:
Although there are several ways to obtain a new cert (a.k.a. "renew"), my main concern would be installing it (and then also automating the renewal process).
So, do you recall how the current cert was obtained and installed?
Do you know which ACME client was used or was it via cPanel?
READERS: Get involved and participate: If you read something you like, then click to like it :heart:
Thanks for your reply
It was obtained through TSOhost and has been renewed through them so far
From what you said I think I will have to wait for them to sort the problem out their end which is a pain, but I don;t think I have any option
Thank you for your advice
Do you have root access to the server?
Or is is on a shared hosting plan?
I am not an expert, but I suspect a shared hosting plan
Ok, then yes.
If you can't login to the server, then you will need them to do that for you :frowning:
Thank you so much for your help & advice
Cheers from Miami :beers:
