Trying to renew cert on nginx but getting "Problem binding to port 443: Could not bind to IPv4 or IPv6"
I’m trying to renew my cert for my personal site, but it seems to be failing (issue with port 443).
Thanks in advance for your help!
My domain is: www.retrosockets.io
/opt/letsencrypt/certbot-auto certonly --standalone
I’ve also tried:
/opt/letsencrypt/certbot-auto-renew
And got the same output.
Please enter in your domain name(s) (comma and/or space separated)  (Enter 'c'
to cancel):www.retrosockets.io retrosockets.io
tls-sni-01 challenge for www.retrosockets.io
tls-sni-01 challenge for retrosockets.io
Problem binding to port 443: Could not bind to IPv4 or IPv6.
My web server is (include version): nginx/1.10.0 (Ubuntu)
Ubuntu 16.04.1 LTS
Digital Ocean
no
I think I resolved this. Had to shut down the nginx server, run the command, and then restart. Not my favorite solution, but it worked.
This happened because you used --standalone. The purpose of that option is to launch a temporary webserver because you don’t have one running.
Next time use the --webroot method, and you’ll be able to use your already running nginx server.
That’s very helpful! Thank you!
