Hello all,
I am having some problems with the certificate for my site https://networkstats.tk
I think there is some issues with the forwarding perhaps.
My domain is: networkstats.tk
root@fs-media:/home/anders# sudo certbot --apache --domains networkstats.tk
http-01 challenge for networkstats.tk
Waiting for verificationâŚ
We were unable to find a vhost with a ServerName or Address of networkstats.tk.
Which virtual host would you like to choose?
1: 000-default.conf | | | Enabled
2: 000-default-le-ssl.conf | networkstats.ml | HTTPS | Enabled
Select the appropriate number [1-2] then [enter] (press âcâ to cancel): 2
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/000-default-le-ssl.conf
new sites, or if youâre confident your site works on HTTPS. You can undo this
change by editing your web serverâs configuration.
Enhancement redirect was already set.
Congratulations! You have successfully enabled https://networkstats.tk
https://www.ssllabs.com/ssltest/analyze.html?d=networkstats.tk
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/networkstats.tk/fullchain.pem
/etc/letsencrypt/live/networkstats.tk/privkey.pem
Your cert will expire on 2020-04-26. To obtain a new or tweaked
with the âcertonlyâ option. To non-interactively renew all of
your certificates, run âcertbot renewâ -
Donating to ISRG / Letâs Encrypt: https://letsencrypt.org/donate
My hosting provider, if applicable, is: Freenom
I can login to a root shell on my machine (yes or no, or I donât know): YES
Iâm using a control panel to manage my site (no, or provide the name and version of the control panel): Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youâre using Certbot): N/A
