Help with setting up letsencrypt
My domain is: networkstats.ml
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): networkstats.ml
http-01 challenge for networkstats.ml
Enabled Apache rewrite module
Waiting for verification…
Failed authorization procedure. networkstats.ml (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://networkstats.ml/.well-known/acme-challenge/Zs1p2MbgDwpZOQ9lubex0JIzS91WuGE0xO1q_m0e19U 92.220.14.129: 400
Domain: networkstats.ml
Detail: Invalid response from
My hosting provider, if applicable, is: freenom
What am i doing wrong?
Hi @andersovreseth
your server sends a http status 400 - Bad request ( https://check-your-website.server-daten.de/?q=networkstats.ml ):
92.220.14.129 400 0.087 M
http://www.networkstats.ml/
92.220.14.129 400 0.086 M
https://networkstats.ml/
92.220.14.129 200 5.953 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
https://www.networkstats.ml/
92.220.14.129 200 5.980 N
http://networkstats.ml/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
http://www.networkstats.ml/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
The result:
Bad Request
This combination of host and port requires TLS.
https://networkstats.ml:80/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
works, so you send https over port 80.
So check / share your port 80 - configuration. There is no ssl allowed.
hmm, yes, probably. How can I change this? Is it an apache setting?
On port 80, there’s a UniFi login screen. Did you perhaps map port 80 to some Ubiquiti device in your router?
External port 80 as wel as port 443 should obviously connect to your Apache server.
Agreed, it seems both 80 and 443 are going to some UniFi SDN device:
forwards to:
https://networkstats.ml/manage/account/login?redirect=%2Fmanage
