Let's Encrypt certificate not be used on Apache running on CentOS 7
I’ve read lots of other support requests on issues with Let’s Encrypt installing incorrectly on CentOS but not sure how to resolve the issue. I think the issue is somehow related to virtual hosts.
Here is the contents on of my /etc/httpd/file:
NameVirtualHost *:80
<VirtualHost *:80>
ServerAdmin email removed
ServerName example.com
ServerAlias example.com
DocumentRoot /var/www/html/example.com/public_html/
ErrorLog /var/www/html/example.com/logs/error.log
CustomLog /var/www/html/example.com/logs/access.log combined
RewriteEngine on
RewriteCond %{SERVER_NAME} =example.com
My domain is: example.com
I ran this command: sudo certbot --apache -d example.com
Enter email address (used for urgent renewal and security notices) (Enter ‘c’ to
cancel): email_removed@reducing_spam.com
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/©ancel: A
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let’s Encrypt project and the non-profit
organization that develops Certbot? We’d like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: N
http-01 challenge for example.com
Waiting for verification…
Created an SSL vhost at /etc/httpd/conf.d/vhost-le-ssl.conf
Deploying Certificate to VirtualHost /etc/httpd/conf.d/vhost-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Redirecting vhost in /etc/httpd/conf.d/vhost.conf to ssl vhost in /etc/httpd/conf.d/vhost-le-ssl.conf
Congratulations! You have successfully enabled https://example.com
https://www.ssllabs.com/ssltest/analyze.html?d=example.com
    /etc/letsencrypt/live/example.com/fullchain.pem
    /etc/letsencrypt/live/example.com/privkey.pem
    Your cert will expire on 2019-11-21. To obtain a new or tweaked
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
  • Your account credentials have been saved in your Certbot
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My web server is (include version): Apache/2.4.6 (CentOS)
The operating system my web server runs on is (include version): Centos 7 64 bit
My hosting provider, if applicable, is: VPS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.36.0
Hi @mrankin
you have created a new certificate
Let's Encrypt Authority X3 2019-08-23 2019-11-21 masteroi.com - 1 entries duplicate nr. 1
So that part works. But you don't use it, instead, there is a self signed certificate ( https://check-your-website.server-daten.de/?q=masteroi.com ):
E=root@masteroi.com, CN=masteroi.com,
OU=SomeOrganizationalUnit, O=SomeOrganization, L=SomeCity,
S=SomeState, C=--
	22.08.2019
	21.08.2020
expires in 363 days
Looks like Certbot doesn't understand your configuration.
What says
apachectl -S (or, if it doesnt work)
httpd -S
That's
wrong. ServerAlias with the same domain name as ServerName is duplicated.
You have a www DNS entry. Perhaps change your ServerAlias to www.masteroi.com and create a certificate with both domain names. Same with your port 443 vHost.
I’ve updated my vhost.conf as follows;
<VirtualHost *:80>
ServerAdmin removed@nothere.com
ServerAlias www.example.com
RewriteEngine on
Have run this command as requested: sudo certbot --apache -d www.example.com
Output:
http-01 challenge for www.example.com
Enhancement redirect was already set.
Congratulations! You have successfully enabled https://www.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=www.example.com
    /etc/letsencrypt/live/www.example.com/fullchain.pem
    /etc/letsencrypt/live/www.example.com/privkey.pem
  • Some rewrite rules copied from /etc/httpd/conf.d/vhost.conf were
    disabled in the vhost for your HTTPS site located at
    /etc/httpd/conf.d/vhost-le-ssl.conf because they have the potential
    to create redirection loops.
Where is the port 443 vHost? Should I just copy and paste the same detail in the vhost.conf file and use port 443 instead like this?
<VirtualHost *:80>
RewriteEngine on
<VirtualHost *:443>
RewriteEngine on
I’ve restarted Apache after making the serveralias change but it has made no difference.
You need both domain names:
-d masteroi.com -d www.masteroi.com
What says
httpd -S
If Certbot doesn't understand your configuration, the wrong vHost is used -> wrong certificate.
[root@example conf.d]# sudo certbot -d example.com -d www.example.com
requested (ref: /etc/letsencrypt/renewal/example.com.conf)
It contains these names: example.com
You requested these names for the new certificate: example.com,
www.example.com.
certificate?
(E)xpand/(C)ancel: e
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Failed redirect for example.com
Unable to set enhancement redirect for example.com
Unable to find corresponding HTTP vhost; Unable to create one as intended addresses conflict; Current configuration does not support automated redirection
  • We were unable to set up enhancement redirect for your server,
    however, we successfully installed your certificate.
    with the "certonly" option. To non-interactively renew all of
httpd -S
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/httpd/conf.d/vhost.conf:1
VirtualHost configuration:
*:443 is a NameVirtualHost
default server example.com (/etc/httpd/conf.d/ssl.conf:56)
port 443 namevhost example.com (/etc/httpd/conf.d/ssl.conf:56)
port 443 namevhost example.com (/etc/httpd/conf.d/vhost-le-ssl.conf:2)
alias example.com
port 443 namevhost example.com (/etc/httpd/conf.d/vhost-le-ssl.conf:16)
alias www.example.com
*:80 example.com (/etc/httpd/conf.d/vhost.conf:3)
ServerRoot: “/etc/httpd”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/etc/httpd/logs/error_log”
Mutex authdigest-opaque: using_defaults
Mutex proxy-balancer-shm: using_defaults
Mutex authdigest-client: using_defaults
Mutex proxy: using_defaults
Mutex authn-socache: using_defaults
Mutex default: dir="/run/httpd/" mechanism=default
PidFile: “/run/httpd/httpd.pid”
Define: _RH_HAS_HTTPPROTOCOLOPTIONS
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“apache” id=48
Group: name=“apache” id=48
Restarted httpd.service after reinstalling certificate but no change, still using self signed certificate.
There
you see the mess.
Every combination of port and domain name must be unique. There is only a test site visible.
So remove all port 443 vHosts.
Your port 80 need both domain names. Then reinstall the existing certificate (don't create a new, you may hit the limit).
No I don’t see the mess. I would have to fully understand it and have experience to see that there is a mess.
I can’t find any instance of “namevhost” in any of those files:
[root@masteroi conf.d]# cat /etc/httpd/conf.d/ssl.conf | grep namevhost
[root@masteroi conf.d]# cat /etc/httpd/conf.d/vhost-le-ssl.conf |grep namevhost
[root@example conf.d]# cat /etc/httpd/conf.d/ssl.conf |grep master
[root@example conf.d]# cat /etc/httpd/conf.d/vhost-le-ssl.conf |grep master
ServerAdmin removed@example
SSLCertificateFile /etc/letsencrypt/live/example.com/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/example.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/example.com/chain.pem
Seems nothing in the first two files for example.com
I’m thinking it’s an issue with how CentOS handles/works with Let’s Encrypt as I’ve seen lots of threads about these types of issues.
Should I rebuild the server with Debian 7 64 bit due to incompatibilities?
Issue resolved by following guide written here - https://linuxize.com/post/secure-apache-with-let-s-encrypt-on-centos-7/
Would recommend anyone installing Let’s Encrypt on CentOS 7 to ONLY use that guide!
Please read
You have three different combinations 443 + masteroi.com. Only one is allowed.
