Same server, different Apache virtual hosts, second- and third-level domains
Hi there
I am afraid this must be in a FAQ. I have just joined Letsencrypt and very much beginner. This is what I need to do:
  • I deliver different web sites from the same server, Debian LAMP, using Apache virtual hosts. So typically I have all sorts of *.conf files in /etc/apache2/sites-available belonging to the different sites.
  • Some sites are third level domains. eg. http://www.example.com.
  • And I have a different set of sites in the format http://example.net/foo, http://example.net/bar, etc.
Right now everything runs fine with HTTP. I want to promote all of them to HTTPS. Does Lets encrypt allow that? If so, could you point me to the instructions?
Hi @ratnaji
that's the standard configuration most users have.
Read the basics
then select a client.
Hi Juergen
Thanks for providing the links! I am used to manually copy the certificates to the server and make them available to httpd. The concept of Let’s Encrypt surprised me.
Yep, it works though. I have already enabled SSL in two web sites, one with the second level domain and one with a third level doman.
The main concept of Letsencrypt is "Automation". Certificates are only 90 days valid, so you have to do that every 60 - 85 day.
Having a lot of domains that doesn't work.
