My domain is: n00bserver.duckdns.org
I ran this command: sudo certbot
It produced this output: Select the appropriate number [1-2] then [enter] (press 'c' to cancel): 1
Deploying certificate
Successfully deployed certificate for n00bserver.duckdns.org to /etc/nginx/conf.d/default.conf
An error occurred and we failed to restore your config and restart your server. Please post to https://communit y.letsencrypt.org/c/help with details about your configuration and this error you received.
Encountered exception during recovery: certbot.errors.MisconfigurationError: nginx restart failed:
nginx: [emerg] bind() to 0.0.0.0:443 failed (98: Address already in use)
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
NEXT STEPS:
- The certificate was saved, but could not be installed (installer: nginx). After fixing the error shown below, try installing it again by running:
certbot install --cert-name n00bserver.duckdns.org
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt /letsencrypt.log or re-run Certbot with -v for more details.
My web server is (include version): Jellyfin.Server 10.10.0.0? I'm not sure if this is what you mean.
The operating system my web server runs on is (include version): Ubuntu 24.04.1 LTS
My hosting provider, if applicable, is: DuckDNS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.11.0
