I made and error sudo certbot certonly --standalone -d example.com -d jtreg.duckdns.org
My domain is: jtreg.duckdns.org
I ran this command: sudo certbot certonly --standalone -d example.com -d jtreg.duckdns.org
I get error:
"Could not bind TCP port 80 because it is already in use by another process on
this system (such as a web server). Please stop the program in question and then
try again."
My web server is (include version): nginx version: nginx/1.22.1
The operating system my web server runs on is (include version): raspbian v. 12.5
My hosting provider, if applicable, is: duckdns
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.1.0
Update:
I stopped ngnix and ran the command:
james@torrentbox:~ $ sudo certbot certonly --standalone -d jtreg.duckdns.org -d jtreg.duckdns.org
Requesting a certificate for jtreg.duckdns.org
Domain: jtreg.duckdns.org
Type: connection
Detail: 140.228.51.50: Fetching http://jtreg.duckdns.org/.well-known/acme-challenge/kZDuWnJ05cWno8GQmh2fF3HRLV2GqNfvezBthJckJmg: Connection refused
Hello @jtreg, welcome to the Let's Encrypt community. :slightly_smiling_face:
Using the online tool Let's Debug yields this result
https://letsdebug.net/jtreg.duckdns.org/1972221
DNSLookupFailed
FATAL
A fatal issue occurred during the DNS lookup process for jtreg.duckdns.org/CAA.
DNS response for jtreg.duckdns.org/CAA did not have an acceptable response code: SERVFAIL
I suggest checking your DNS configuration and that the Name Servers are functioning properly to serve the CAA DNS Record.
Edit: also see the ERRORs here jtreg.duckdns.org | DNSViz
Hi @jtreg,
Looks like there has been some improvement in the DNS;
however using --standalone we will still see "ERRORs"
See this for more advise Certbot stand-alone return error Timeout during connect (likely firewall problem) - #4 by MikeMcQ
https://letsdebug.net/jtreg.duckdns.org/1975336
ANotWorking
ERROR
jtreg.duckdns.org has an A (IPv4) record (140.228.51.50) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Get "http://jtreg.duckdns.org/.well-known/acme-challenge/letsdebug-test": dial tcp 140.228.51.50:80: connect: connection refused
Trace:
@0ms: Making a request to http://jtreg.duckdns.org/.well-known/acme-challenge/letsdebug-test (using initial IP 140.228.51.50)
@0ms: Dialing 140.228.51.50
@5830ms: Experienced error: dial tcp 140.228.51.50:80: connect: connection refused
IssueFromLetsEncrypt
ERROR
A test authorization for jtreg.duckdns.org to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
140.228.51.50: Fetching http://jtreg.duckdns.org/.well-known/acme-challenge/pcm9l1q-PBtH-JBgZo766OC7rIeSotEpU0Rp2TqMMI4: Connection refused
Using nmap shows Port 80 & 443 are filtered (i.e. blocked)
$ nmap -Pn -p80,443 jtreg.duckdns.org
Starting Nmap 7.94SVN ( https://nmap.org ) at 2024-05-23 11:39 PDT
Nmap scan report for jtreg.duckdns.org (140.228.51.50)
Host is up.
rDNS record for 140.228.51.50: 51.228.140.50.bcube.co.uk
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.52 seconds
Seeing the above indicates the use of HTTP-01 challenge the most common; and states
"The HTTP-01 challenge can only be done on port 80."
Best Practice - Keep Port 80 Open
Hi @jtreg,
Consider using certbot --nginx instead of certbot certonly --standalone, since you already have a running web server (nginx). The --standalone method is usually intended for cases where you don't have a web server running on your server.
Considering the connection failures, please also make sure that your DuckDNS software is correctly updating your server IP address, and that you don't have a firewall or router set to prevent incoming connections from the Internet on port 80 (or a residential ISP that prohibits them).
Or --webroot if you don't want Certbot to make changes to your webserver.
I agree that using --standalone doesn't make much sense when there already is a webserver running.
