Too many redirects on certificate renewal
My domain is: my.immerseme.co
I ran this command: ./certbot-auto
It produced this output: IMPORTANT NOTES:
    /etc/letsencrypt/live/my.immerseme.co/fullchain.pem
    /etc/letsencrypt/live/my.immerseme.co/privkey.pem
    Your cert will expire on 2020-08-04. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again with the “certonly” option. To non-interactively renew all
    of your certificates, run “certbot-auto renew”
My web server is (include version): Cloudflare
The operating system my web server runs on is (include version): Linux Ubuntu
My hosting provider, if applicable, is: Cloudflare?
After running this command the site was working well and I thought I had renewed the existing certificate. I found a couple of hours later the site was down and we had this error displayed:
This page isn’t working
my.immerseme.co redirected you too many times.
[Try clearing your cookies]
ERR_TOO_MANY_REDIRECTS
Any help would be so highly appreciated, fixing this issue is really urgent, we have thousands of new users waiting to use the site.
Hi @tomasbrown
then check your domain with "check your website", then you should see, if you have a http -> https -> http redirect or a https -> https. Then fix it.
Hi @JuergenAuer
The result I got from Redirect-checker.org is:
https://my.immerseme.co
301 Moved Permanently
https://my.immerseme.co/
I am new to this so unsure how to fix an https -> https error, do you have any advice on where this may originate from?
Now there is a check of your domain - https://check-your-website.server-daten.de/?q=my.immerseme.co
Grade B, no loop.
Looks like you have found and removed that wrong redirect https -> https. :+1:
