I ran this command: ./certbot-auto certonly --webroot -w /var/www/html/ -d crabwp.com -d www.crabwp.com
My hosting provider, if applicable, is: Google Cloud
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): -bash: certbot-auto: command not found Too many redirects
** To fix these errors, please make sure that your domain name was**
** entered correctly and the DNS A/AAAA record(s) for that domain**
** contain(s) the right IP address. Additionally, please check that**
** your computer has a publicly routable IP address and that no**
** firewalls are preventing the server from communicating with the**
** client. If you’re using the webroot plugin, you should also verify**
** that you are serving files from the webroot path you provided.**
The IP address is 34.80.120.253 and I am currently able to access the website via that address. Help me.
Challenge failed for domain crabwp.com
Challenge failed for domain www.crabwp.com
http-01 challenge for crabwp.com
http-01 challenge for www.crabwp.com
I received another error
./certbot-auto has insecure permissions!
To learn how to fix them, visit Certbot-auto deployment best practices
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Domain: crabwp.com
Type: dns
Detail: No valid IP addresses found for crabwp.com
Domain: www.crabwp.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.crabwp.com
I pointed to the correct ip but the error still occurs
Domain: crabwp.com
Type: dns
Type: dns
Detail: No valid IP addresses found for www.crabwp.com
