ERR_TOO_MANY_REDIRECTS after running certbot
wildmadagascar.org
sudo certbot certonly --apache
requested (ref: /etc/letsencrypt/renewal/www.wildmadagascar.org.conf)
It contains these names: www.wildmadagascar.org
You requested these names for the new certificate: wildmadagascar.org,
certificate?
(E)xpand/(C)ancel: E
Renewing an existing certificate for wildmadagascar.org and www.wildmadagascar.org
Certificate is saved at: /etc/letsencrypt/live/www.wildmadagascar.org/fullchain.pem
Key is saved at: /etc/letsencrypt/live/www.wildmadagascar.org/privkey.pem
This certificate expires on 2023-09-03.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
GNU/Linux 5.11.0-1022-aws x86_64
Ubuntu 20.04.3
Yes
No
certbot 2.6.0
This is caused by Cloudflare's CDN connecting to your origin server insecurely. Go to Cloudflare → SSL/TLS → Overview and set your Encryption Mode to "Full" or "Full/Strict":
