Too many redirect issue wordpress
My domain is: GIANKUMAR.COM
I ran this command: I RENEWED THE SSL
It produced this output: RENEWAL OF SSL IS SUCCESSFUL BUT MY WEBSITE IS NOT WORKING
My web server is (include version): GOOGLE CLOUD WORDPRESS
I can login to a root shell on my machine (yes or no, or I don’t know): YES
Resolving www.giankumar.com (www.giankumar.com)... 34.93.174.157
Connecting to www.giankumar.com (www.giankumar.com)|34.93.174.157|:443... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
--2019-12-23 10:01:52--  https://www.giankumar.com/
Reusing existing connection to www.giankumar.com:443.
it try to redirect to itself, it can’t work.
Thanks for your message Please help me out what should i do. Im not too much technical
it’s a vps, only you and god know how you installed your wordpress on google cloud (VPS), and I think now only god knows.
Hi @poniaajay
checking your domain you see the problem - https://check-your-website.server-daten.de/?q=giankumar.com
http://giankumar.com/ 34.93.174.157 301 https://giankumar.com/ Html is minified: 100,00 % 0.750 A
http://www.giankumar.com/ 34.93.174.157 301 https://www.giankumar.com/ Html is minified: 100,00 % 0.750 A
https://giankumar.com/ 34.93.174.157 301 https://www.giankumar.com/ Html is minified: 100,00 % 10.154 B
https://www.giankumar.com/ 34.93.174.157 301 https://www.giankumar.com/ Html is minified: 100,00 % 9.874 L
https + non-www redirects to https + www, that's ok.
But https + www redirects to https + www, that's a direct loop you have created.
So remove that wrong redirect. May be your wordpress, htaccess or your Rewrite rule.
