Hi, I Use TokanWeb for Cloud Hosting
Also my DNS record is on Cloudflare
I have Problem On flexible SSL
My Wordpress is Looping Redirect (too many redirect )
Hi @baratabletam, and welcome to the LE community forum ![]()
"too many redirect" is usually due to the CDN connecting to your server via HTTP.
Here is what happens:
- client makes an HTTP request
- CDN redirects them to HTTPS
- client makes an HTTPS request
- CDN tries to get content from your server via HTTP
- your server redirects that HTTP request to HTTPS
- CDN replies to client "you must connect to HTTPS"
Do you see the problem?
Don't use that. It is deliberately insecure and, as you have discovered, frequently causes redirect loops. Only use Full (strict).
https://community.cloudflare.com/t/why-you-should-choose-full-strict-and-only-full-strict/286652
