I have cloudflare redirecting the DNS stuff, I’ve tried setting the SSL certificates to “Full (strict)” but that only gives me a 522 error. I don’t really know what to supply beyond this point, but I can get you configs and such.
ssllabs reports its fine (without full strict on CF)
(To be clear: it gives me “too many redirects” without CF, and a 522 with)
Well, you’ve got a HTTP to HTTPS redirect set up. Which is GOOD! Because with TLS configured, you’d automatically want people to go to the secure site, obviously.
But you also have a HTTPS to HTTPS redirect! Which is BAD! Because when people already are on your secure site, there’s no need to redirect them again… You just want them to see your site!
So you’ve got to check your webservers configuration which is responsible for the HTTP to HTTPS redirect and see if it’s working properly. It should only redirect when people are surfing to the HTTP site.
Can you please share the portion of you config file that redirects http to https? Below is an example of such a redirect. You config file might be the reason why you are getting too many redirects.
listen 80;
server_name www.domain.com domain.com;
# redirects both www and non-www to https
return 301 https://domain.com$request_uri;
listen 443 ssl http2;
server_name www.domain.com;
# redirects www to non-www
return 301 $scheme://domain.com$request_uri;
I’ve gotten closer than what I was. Currently google shows the site as “unsafe” and when I proceed, it gets me to my router login (not where I want to go)
