Thank you for looking at this. I thought I followed the install instructions, but now have a non-working website that says
“Err_Too_Many_redirects”
Any help is greatly appreciated or any suggestions.
My domain is: nextstudy.org
I ran this command: I followed the SSL cert installation
It produced this output: It said the SSL cert was installed. But when I go to the site it says, err_too_many_redirects
My web server is (include version): Google Cloud - Debian/Jessie
The operating system my web server runs on is (include version): Debina/Jessie/ Apache/2.4.10 (Debian)
I can login to a root shell on my machine (yes or no, or I don’t know): Not able to log-in to Wordpress, but can log into GoogleCloud
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Certbot—
Below is the installation process:
Connected, host fingerprint: ssh-rsa 0 48:D0:FB:E1:34:D0:66:92:0B:FA:37:79:B9:23
:DB:8C:DB:F9:B9:40
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Jun 10 23:07:09 2019 from 74.125.72.34
doug@wordpress-nextstudy-vm:~$ wget https://dl.eff. org/certbot-auto && chmod a+x certbot-auto
--2019-06-18 00:09:34-- https://dl.eff.org/certbot-auto
Resolving dl.eff. org (dl.eff.org)... 151.101.0.201, 151.101.64.201, 151.101.128.201, ...
Connecting to dl.eff .org (dl.eff.org)|151.101.0.201|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 68023 (66K) [application/octet-stream]
Saving to: ‘certbot-auto.2’
certbot-auto.2 100%[================================================>] 66.43K --.-KB/s in 0.02s
2019-06-18 00:09:34 (3.38 MB/s) - ‘certbot-auto.2’ saved [68023/68023]
doug@wordpress-nextstudy-vm:~$ ./certbot-auto certonly --webroot -w /opt/bitnami/apps/wordpress/htdocs/ -d nextstudy.com -d www.nextstudy. com
doug@wordpress-nextstudy-vm:~$ $ mkdir /tmp/apache_config_backup/
-bash: $: command not found
doug@wordpress-nextstudy-vm:~$ $ cp -r /etc/apache2/* /tmp/apache_config_backup/
doug@wordpress-nextstudy-vm:~$ mkdir /tmp/apache_config_backup/
doug@wordpress-nextstudy-vm:~$ cp -r /etc/apache2/* /tmp/apache_config_backup/
doug@wordpress-nextstudy-vm:~$ sudo apt-get install python-certbot-apache -t stretch-backports
Reading package lists... Done
doug@wordpress-nextstudy-vm:~$ sudo apt-get install git
The following NEW packages will be installed:
git git-man libcurl3-gnutls liberror-perl rsync
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 5,641 kB of archives.
After this operation, 25.5 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http: //deb.debian.org/debian/ jessie/main liberror-perl all 0.17-1.1 [22.4 kB]
Get:2 http ://security.debian.org/ jessie/updates/main libcurl3-gnutls amd64 7.38.0-4+deb8u15 [251 kB]
Get:3 http ://security.debian.org/ jessie/updates/main git-man all 1:2.1.4-2.1+deb8u7 [1,269 kB]
Get:4 http://security.debian.org/ jessie/updates/main git amd64 1:2.1.4-2.1+deb8u7 [3,709 kB]
Get:5[ http://security.debian. org/](http://security.debian .org/) jessie/updates/main rsync amd64 3.1.1-3+deb8u2 [390 kB]
Fetched 5,641 kB in 0s (10.2 MB/s)
Selecting previously unselected package libcurl3-gnutls:amd64.
(Reading database ... 62461 files and directories currently installed.)
Preparing to unpack .../libcurl3-gnutls_7.38.0-4+deb8u15_amd64.deb ...
Unpacking libcurl3-gnutls:amd64 (7.38.0-4+deb8u15) ...
Selecting previously unselected package liberror-perl.
Preparing to unpack .../liberror-perl_0.17-1.1_all.deb ...
Unpacking liberror-perl (0.17-1.1) ...
Selecting previously unselected package git-man.
Preparing to unpack .../git-man_1%3a2.1.4-2.1+deb8u7_all.deb ...
Unpacking git-man (1:2.1.4-2.1+deb8u7) ...
Selecting previously unselected package git.
Preparing to unpack .../git_1%3a2.1.4-2.1+deb8u7_amd64.deb ...
Unpacking git (1:2.1.4-2.1+deb8u7) ...
Selecting previously unselected package rsync.
Preparing to unpack .../rsync_3.1.1-3+deb8u2_amd64.deb ...
Unpacking rsync (3.1.1-3+deb8u2) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for systemd (215-17+deb8u13) ...
Setting up libcurl3-gnutls:amd64 (7.38.0-4+deb8u15) ...
Setting up liberror-perl (0.17-1.1) ...
Setting up git-man (1:2.1.4-2.1+deb8u7) ...
Setting up git (1:2.1.4-2.1+deb8u7) ...
Setting up rsync (3.1.1-3+deb8u2) ...
Processing triggers for libc-bin (2.19-18+deb8u10) ...
doug@wordpress-nextstudy-vm:~$ sudo git clone[ https: //github.com/certbot/certbot.git](https://github. com/certbot/certbot.git)
Cloning into 'certbot'...
remote: Enumerating objects: 38, done.
remote: Counting objects: 100% (38/38), done.
remote: Compressing objects: 100% (34/34), done.
remote: Total 66269 (delta 10), reused 15 (delta 4), pack-reused 66231
Receiving objects: 100% (66269/66269), 21.74 MiB | 22.51 MiB/s, done.
Resolving deltas: 100% (48464/48464), done.
Checking connectivity... done.
doug@wordpress-nextstudy-vm:~$ cd certbot
doug@wordpress-nextstudy-vm:~/certbot$ ./certbot-auto
Requesting to rerun ./certbot-auto with root privileges...
./certbot-auto has insecure permissions!
To learn how to fix them, visit[ https://community.letsencrypt. org/t/certbot-auto-deployment-best-practices/91979/](https://community.letsencrypt. org/t/certbot-auto-deployment-best-practices/91979/)
Creating virtual environment...
Installing Python packages...
Installation succeeded.
1: nextstudy. org
2: www.nextstudy. org
http-01 challenge for nextstudy.org
http-01 challenge for www.nextstudy. org
Created an SSL vhost at /etc/apache2/sites-available/wordpress-le-ssl. conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/wordpress-le-ssl. conf
Enabling available site: /etc/apache2/sites-available/wordpress-le-ssl. conf
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Future versions of Certbot will automatically configure the webserver so that all requests redirect to secure HTTPS
access. You can control this behavior and disable this warning with the --redirect and --no-redirect flags.
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://nextstudy.org and
[https://www.nextstudy.org](https://www.nextstudy. org/)
https://www.ssllabs.com/ssltest/analyze.html?d=nextstudy. org
https://www.ssllabs.com/ssltest/analyze.html?d=www.nextstudy. org
/etc/letsencrypt/live/nextstudy.org/fullchain. pem
/etc/letsencrypt/live/nextstudy.org/privkey. pem
Your cert will expire on 2019-09-15. To obtain a new or tweaked
version of this certificate in the future, simply run certbot-auto
again with the "certonly" option. To non-interactively renew *all*
of your certificates, run "certbot-auto renew"
