Too many failed authentications using certbot --nginx
My domain is: www,xuuki.xyz
I ran this command: cerbot --nginx
It produced this output: An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/
My web server is (include version): not sure how to answer this
The operating system my web server runs on is (include version): Debian
My hosting provider, if applicable, is: Vultr and Epik
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Cerbot 0.31.0
Thanks you very much in advance. This will hopefully help me learn more about setting up a webserver
I hope to give some helpful info here. This is the output of certbot --nginx: Which names would you like to activate HTTPS for?
1: xuuki.xyz
2: mail.xuuki.xyz
3: www.mail.xuuki.xyz
4: www.xuuki.xyz
blank to select all options shown (Enter ‘c’ to cancel): 1 4
http-01 challenge for www.xuuki.xyz
nginx: [warn] conflicting server name “xuuki.xyz” on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name “www.xuuki.xyz” on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name “xuuki.xyz” on [::]:80, ignored
nginx: [warn] conflicting server name “www.xuuki.xyz” on [::]:80, ignored
Waiting for verification…
Failed authorization procedure. www.xuuki.xyz (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.xuuki.xyz/.well-known/acme-challenge/09Ug9LHNYz9cojzjPHK1PTPvV2YKtQQy6adsvIpw-vc [2001:19f0:7400:87c8:5400:2ff:fee1:67e6]: “\r\n404 Not Found\r\n<body bgcolor=“white”>\r\n
404 Not Found
\r\n
    Domain: www.xuuki.xyz
    Detail: Invalid response from
    404 Not
    Found
    \r\n
Hi @vyvyanmar
there
is your job. You have multiple definitions, that's always wrong. Merge all duplicated definitions.
Thanks @JuergenAuer. May you show me how to merge all duplicated definitions?
I wasnt sure where nginx was storing these definitions to see the dupications I have to merge. I’ve checked the nginx man page for anything about merging or duplicates but I havent found the correct command yet … Ah or its possibly because the default file is in /etc/nginx/sites-enabled, perhaps getting rid of that should work. :slight_smile:
…which is has thank you very much for your help! :smiley: This is my first website online now woohoo!
