Hello
Do you know if the .basketball TLD will be supported in a near future ?
If yes, is there any "calendar" available ?
Thx
Sylvain
Hello
Thx
Sylvain
Have you tried it?
What error did you get?
[please use the staging environment for all testing]
I ask because root DNS servers seem to know where .basketball
is:
basketball nameserver = a.nic.basketball
basketball nameserver = b.nic.basketball
basketball nameserver = c.nic.basketball
basketball nameserver = d.nic.basketball
.basketball
has been on the PSL for quite a while, Let's Debug reports no issues with the TLD so I don't see any reason why it would not be supported.
I received an error from certbot stating that the TLD was not supported.
but changing the method allowed me to generate the SSL certificate
Thanks for the quick reply !
