datapulse.asuscomm.com
docker compose run --rm certbot certonly --webroot --webroot-path=/var/www/certbot --email tanuj.shriyan.nfirelabs@gmail.com --agree-tos --no-eff-email -d datapulse.asuscomm.com
WARN[0000] /home/nfire-server/datapulse/docker-compose.yml: version is obsolete
[+] Creating 3/0
:heavy_check_mark: Container datapulse-db-1 Running 0.0s
:heavy_check_mark: Container datapulse-django-1 Running 0.0s
:heavy_check_mark: Container datapulse-nginx-1 Running 0.0s
Requesting a certificate for datapulse.asuscomm.com
Domain: datapulse.asuscomm.com
Type: connection
Detail: 77.86.41.19: Fetching http://datapulse.asuscomm.com/.well-known/acme-challenge/hf-QozVfo6h2kSk2g9VWWL2t1F_CoVD_j7IpZg6x7KU: Timeout during connect (likely firewall problem)
Unsure. I am running the server on Nginx
Ubuntu
I don#t know
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.11.0
Hello @tanujshriyan, welcome to the Let's Encrypt community. :slightly_smiling_face:
As shown below, Singapore maybe being geo blocked.
Please read these:
Thanks for replying @Bruce5051 but I am not in Singapore. I am in United Kingdoms
@tanujshriyan Let's Encrypt sends multiple HTTP requests from various locations around the world. Your error said this request failed and Bruce thought maybe it was because of the check from the Singapore servers.
I don't think that was why you saw timeout. If the only failure was from there we should see "Secondary" in the error message and we did not.
I checked connections to your domain from various places this morning and all looks good.
Does the problem repeat?
And, why are you getting another cert so soon after your last one on Jun14? Renewals are recommended for 90-day certs 30 days before expiry.
@tanujshriyan to explain why I check Singapore, doesn't matter that you are in the United Kingdom or anywhere else on the planet, please read these:
