My domain is: muxxlenetzwerk.at
I ran this command: ./letsencrypt-auto --d muxxlenetzwerk.at
    Domain: muxxlenetzwerk.at
    Type: connection
    Detail: Fetching
    http://muxxlenetzwerk.at/.well-known/acme-challenge/UheZlUFRuuuJOHNLoreK6AXV_5lKpf5mFa3emNO33vg:
My web server is (include version): Apache/2.4.38
The operating system my web server runs on is (include version): Raspian
My hosting provider, if applicable, is: Mine Server, Godaddy domain
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Someone know whats the problem? Maybe he can help me when we both on discord?
Hi @xCallMeNoah
your configuration is buggy, I don't think that can work - see your check, one day old - https://check-your-website.server-daten.de/?q=muxxlenetzwerk.at
Host Type IP-Address is auth. ∑ Queries ∑ Timeout
muxxlenetzwerk.at A 85.127.54.22 Graz/Styria/Austria (AT) - UPC Austria - B2C Networkblock Hostname: 85-127-54-22.dsl.dynamic.surfer.at yes 2 0
A 94.130.99.154 Nuremberg/Bavaria/Germany (DE) - Hetzner Online GmbH Hostname: static.154.99.130.94.clients.your-server.de yes 2 0
A 184.168.131.241 Scottsdale/Arizona/United States (US) - GoDaddy.com, LLC Hostname: ip-184-168-131-241.ip.secureserver.net yes 2 0
AAAA yes
One domain name with
  • a dynamic ip address
  • a Hetzner ip
  • a GoDaddy secureserver.net?
Looks like two of these ip addresses are wrong.
So Letsencrypt checks the wrong ip - and the server doesn't answer.
Running into the same thing this morning, running checks via https://letsdebug.net is showing intermittent resolution, more than likely related to the CenturyLink/Cloudflare outages this morning. I think we’re stuck playing the waiting game until the upstream DNS provider is back to normal operation.
The main problem is the provider of the domain I think. The hetzner server was my old server. The dynamic ip adress is at the moment my provider where my server is connected
Then you have to remove the other two ip addresses.
The problem is that I don’t know how to remove them.
You use GoDaddy or HostEurope to manage your domains - ns43.domaincontrol.com - there you have to remove these entries.
That’s not the job of the provider, that’s your setup.
ns43.domaincontrol.com is a nameserver from GoDaddy
@JuergenAuer do you have discord? Maybe you can help me with seeing my screen.
Ah I found my problem what you meant, thank you!
Yep, now the newest check has only one ip address. And a new certificate:
CN=muxxlenetzwerk.at
	30.08.2020
	28.11.2020
expires in 90 days	muxxlenetzwerk.at, www.muxxlenetzwerk.at - 2 entries
