[Solved] Letsencrypt-auto not connecting to server?
My domain is:pdhsp.focusrite.ath.cx
I ran this command: ./letsencrypt-auto --apache -d pdhsp.focusrite.ath.cx
root@guyvaio:~/letsencrypt# ./letsencrypt-auto --apache -d pdhsp.focusrite.ath.cx
http-01 challenge for pdhsp.focusrite.ath.cx
Waiting for verification…
Failed authorization procedure. pdhsp.focusrite.ath.cx (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://pdhsp.focusrite.ath.cx/.well-known/acme-challenge/o2ePzi-p5j2JV3YU99ck-oxHsQaT8Ns9nAEqtbq5cng: Timeout
    Domain: pdhsp.focusrite.ath.cx
    Type: connection
    Detail: Fetching
    Timeout
My web server is (include version): Apache/2.4.27 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu Artful
My hosting provider, if applicable, is: localhost
Already have another domain on .focusrite.ath.cx (DynDNS) which has an LE cert on it and that renews and everything, tried it today. However the above pdhsp domain claims it times out when trying to connect. When watching the Apache log scroll by no connection attempt ever appears to be made. I can load the URL fine from the public internet e.g. Amazon AWS server and log entries appear so it is definitely connectable from the web and it is the correct logfile that’s showing no activity during certificate request.
Normally LE just works (run as root).
The site is a dev version running on a laptop which needs HTTPS to make Google Geolocation work.
Additionally an inotifywait watching the web root folder sees no activity with .well-known being created which I assume happens as part of the validation round trip?
Hi @surefyre,
Your domain has an AAAA record so Let’s Encrypt is trying to reach the domain challenge using the IPv6 address but no way, it always timeout…
$ curl -IkLv6 http://pdhsp.focusrite.ath.cx/.well-known/acme-challenge/o2ePzi-p5j2JV3YU99ck-oxHsQaT8Ns9nAEqtbq5cng
*   Trying 2a02:c7f:2213:c500::1...
* TCP_NODELAY set
* connect to 2a02:c7f:2213:c500::1 port 80 failed: Connection timed out
* Failed to connect to pdhsp.focusrite.ath.cx port 80: Connection timed out
* Closing connection 0
curl: (7) Failed to connect to pdhsp.focusrite.ath.cx port 80: Connection timed out
There is no problem reaching your domain using IPv4 so, or you fix your IPv6 conf or you remove the AAAA record for domain pdhsp.focusrite.ath.cx.
Good luck,
sahsanu
Thanks Sahsanu, will see if I can bin the AAAA from DynDns. IPV6 always catches me out!
My retry timeout just expired, deleting the IPV6 entry in DynDns worked perfectly, thanks!
Perhaps it’s worth an IPV6 comment in the error message output during validation attempt if any LE devs are reading?
