http-01 challenge for slyy.testapp.win
Waiting for verification…
Failed authorization procedure. slyy.testapp.win (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://slyy.testapp.win/.well-known/acme-challenge/Kexst56VnlPm0lK8YE66DVXDfkXH--DDpYF3qQznB50: Timeout during connect (likely firewall problem)
Cent OS 7.5
If you don’t have a web server yet, you can use the standalone authenticator.
letsencrypt-auto certonly -a standalone --preferred-challenges http
But you’ll need to make sure that your server’s firewall permits port 80, and that traffic from the internet can reach your server (e.g. ports forwarded on any routers/NAT).
Since your server is in China, you’ll also need to make sure that any website licenses are also sorted out.
I have tried this command,however,it didn’t work as well
[root@localhost letsencrypt]# ./letsencrypt-auto certonly -a standalone --preferred-challenges http
Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’
to cancel): slyy.testapp.win
Failed authorization procedure. slyy.testapp.win (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://slyy.testapp.win/.well-known/acme-challenge/3JmHwQQdwuodVxyxBLJdsYBwc-_v45I-TB7_fl9ks9I: Timeout during connect (likely firewall problem)
thank you very much,at least this command I have felt the hope,althoght it failed
An unexpected error occurred:
There were too many requests of a given type :: Error creating new authz :: too many failed authorizations recently: see Rate Limits - Let's Encrypt
