altamira.prot-on.com
certbot certonly --manual -d altamira.prot-on.com
http-01 challenge for altamira.prot-on.com
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you’re running certbot in manual mode on a machine that is not
your server, please ensure you’re okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: Y
Create a file containing just this data:
xanfR0jX6bI6-MFYe7nTwfMbSjy561SJWq0yA6JMwfY.A4cighAvPn0QslYGL5-_z1TXNN8TuJ-6D6PBYSoR2EI
http://altamira.prot-on.com/.well-known/acme-challenge/xanfR0jX6bI6-MFYe7nTwfMbSjy561SJWq0yA6JMwfY
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. altamira.prot-on.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://altamira.prot-on.com/.well-known/acme-challenge/xanfR0jX6bI6-MFYe7nTwfMbSjy561SJWq0yA6JMwfY: Timeout during connect (likely firewall problem)
    Domain: altamira.prot-on.com
    Type: connection
    Detail: Fetching
Apache/2.4.29
Ubuntu 18.0.4
Yes
No
0.31.0
I’ve checked from a browser (out of any VPN):
it returns the given value.
The server failed to auto renew due to firewall problems after solving the issue with firewall the same error persists. Then I deleted the certificate to create a new one and I removed 443 VirtualHost in apache, but I get same error, with both --apache and --manual.
Thanks in advance for your help!
Oscar
It times out for me, too.
Did you try from inside your network or from another network?
Are you sure the IP address (52.236.154.94) is correct, and there isn't a firewall blocking all Internet traffic, or traffic from other ISPs, or traffic from other countries, or something?
Oh, curious. I see the content.
Looks like a regional blocking (I'm from Berlin).
You are right!! We didn’t realize about a regional constraint.
Now it is working, and I got the certificate.
Thanks for your help,
Oscar
