Timeout during connect (likely firewall problem) but ports are open
megasweden.se, nabaxo.dev, nabaxo.io and a few more
sudo certbot --nginx -v
Renewing an existing certificate for nabaxo.asuscomm.com and 16 more domains
http-01 challenge for www.megasweden.se
Challenge failed for domain www.megasweden.se
  Domain: www.megasweden.se
  Type:   connection
  Detail: 155.4.192.55: Fetching http://www.megasweden.se/.well-known/acme-challenge/dzmFLIRBpcCegrUhY-Fes0U5tamQRBKkLMxOR6IYA_E: Timeout during connect (likely firewall problem)
The "..." is just duplicate entries with other domain names.
nginx/1.22.1
Raspbian 12
n/a
no
certbot 3.1.0
So, when I check with a port scanner, it says ports 80 and 443 are open, but when I check with letsdebug.net, it gives me an error. I have no idea what's going on.
How did you check this exactly?
Because from my point of view nothing is open to the public internet and this is corroborated by websites like https://check-host.net/check-http?host=www.megasweden.se for most locations. Only two sites (France and Switzerland) seem to be able to connect.
Any geo blocking going on perhaps?
Edit:
Weird, if I run that tool a second time, just two other countries show up, but Switzerland is gone. Some weird firewall you have. It's different every time.
It's super weird, right? When I check my actual IP: Port Checker - Check Open Ports Online
It's fine...
Not when I run it. Only port 8443 was open when I checked the Server ports.
Edit: and of course a second time port 80 and 443 are open. But a third time they're not.
Please check any firewall for this behaviour or perhaps ask your ISP about it.
Thanks for the help mate!
For future reference, it was my router that decided to turn on DoS protection. :person_facepalming:
