Failed authorization procedure. Timeout during connect (likely firewall problem)
Hello,
it was working fine for me before, but now I cannot get certificate for any new domain nor can update existing certificates. Tried automatically and manually.
Certificates are expiring and I cannot renew them for some reason.
Port 80 is open, firewall is letting it through, but somehow it still wouldn't work.
What could be the problem? It was working fine before
INFO:
My domain is: restreamer.beesport.online
I ran this command: sudo certbot --nginx -d restreamer.beesport.online and sudo certbot --renew
http-01 challenge for restreamer.beesport.online
Failed authorization procedure. restreamer.beesport.online (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://restreamer.beesport.online/.well-known/acme-challenge/Pzd53lAVuswp9GhWCeXCrtUiVTRZNqc-Uqo1wGY8tjo: Timeout during connect (likely firewall problem)
    Domain: restreamer.beesport.online
    Type: connection
    Detail: Fetching
My web server is (include version): Nginx proxy - nginx/1.14.2
The operating system my web server runs on is (include version): Debian GNU/Linux 10 (buster)
My hosting provider, if applicable, is: NA
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
I think you may be geoblocking requests to your site, so you are inadvertently blocking validation requests from Let's Encrypt.
Thank you. It was not geoblocked but our Mikrotik blocked all lets encrypt attempts. Thanks for pointing to the right direction!
If Mikrotik allows, you should Geoblock block HTTPS (but not HTTP).
You could handle the global ACME challenge requests in HTTP and forward all else to HTTPS.
For nginx, try something like:
  location ^/(?!\.well-known) {            # skip challenge requests
    return 301 https://$host$request_uri;  # send all requests to HTTPS
  }# location
  root /new/dedicated/challenge/path;
