My domain is: bld-team.tech
I ran this command: sudo certbot --nginx -v
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: bld-team.tech
2: www.bld-team.tech
(ref: /etc/letsencrypt/renewal/www.bld-team.tech.conf)
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for bld-team.tech and www.bld-team.tech
http-01 challenge for www.bld-team.tech
Challenge failed for domain www.bld-team.tech
Domain: www.bld-team.tech
Type: connection
Detail: 5.180.30.76: Fetching http://www.bld-team.tech/.well-known/acme-challenge/0IRHaSOHDY4xzVUo2DBZNd25ddqY6maZ4PYHLOwTtYM: Timeout during connect (likely firewall problem)
Nginx 1.18.0
Ubuntu 22.04
My hosting provider, if applicable, is: perfect quality hosting
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.11.0
I have also tried curl presented URL. That's what I've got:
curl http://www.bld-team.tech/.well-known/acme-challenge/AEwo0sVoje3gsf965b2ARTANGWp2uNuLgHjFU3tVdTw
301 Moved Permanently
nginx/1.18.0 (Ubuntu)
