Certbot renewal fails with "Time out during connect (likely firewall problem)" warning
My domain is: lawlec.korea.ac.kr
2025-11-12 09:53:31,958:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz/1196656447/611509808046 HTTP/1.1" 200 1081
2025-11-12 09:53:31,959:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Wed, 12 Nov 2025 00:53:31 GMT
Content-Length: 1081
Boulder-Requester: 1196656447
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index"
Replay-Nonce: 9cWC3FLMELUTI_tQ6BDDbL1szktgvMdVOEwPmIIWwdWvW901YyU
X-Frame-Options: DENY
"identifier": {
"type": "dns",
"value": "lawlec.korea.ac.kr"
"status": "invalid",
"expires": "2025-11-19T00:53:13Z",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall/1196656447/611509808046/8vfWYQ",
"validated": "2025-11-12T00:53:17Z",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "163.152.93.105: Fetching http://lawlec.korea.ac.kr/.well-known/acme-challenge/K7z9ZQ72GcFSYHSpWRRVUK1GhovUzonZQsehjapUwd8: Timeout during connect (likely firewall problem)",
"status": 400
"token": "K7z9ZQ72GcFSYHSpWRRVUK1GhovUzonZQsehjapUwd8",
"validationRecord": [
"url": "http://lawlec.korea.ac.kr/.well-known/acme-challenge/K7z9ZQ72GcFSYHSpWRRVUK1GhovUzonZQsehjapUwd8",
"hostname": "lawlec.korea.ac.kr",
"port": "80",
"addressesResolved": [
"163.152.93.105"
"addressUsed": "163.152.93.105"
2025-11-12 09:53:31,960:DEBUG:acme.client:Storing nonce: 9cWC3FLMELUTI_tQ6BDDbL1szktgvMdVOEwPmIIWwdWvW901YyU
2025-11-12 09:53:31,961:INFO:certbot._internal.auth_handler:Challenge failed for domain lawlec.korea.ac.kr
2025-11-12 09:53:31,962:INFO:certbot._internal.auth_handler:http-01 challenge for lawlec.korea.ac.kr
2025-11-12 09:53:31,962:DEBUG:certbot._internal.display.obj:Notifying user:
Domain: lawlec.korea.ac.kr
Type: connection
Detail: 163.152.93.105: Fetching http://lawlec.korea.ac.kr/.well-known/acme-challenge/K7z9ZQ72GcFSYHSpWRRVUK1GhovUzonZQsehjapUwd8: Timeout during connect (likely firewall problem)
My web server is (include version): Apache/2.4.52 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 22.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 5.1.0
The web server that responds is Server: Apache/2.4.52 (Ubuntu) but you are running certbot in nginx mode, so the challenge response will likely be being written to the wrong place (the nginx web server files etc).
From what I see, the server appears to be nginx in the posted error, but Apache mode is being used. That doesn't explain the timeout though.
The nginx server replies are the ones from Let's Encrypt's servers.
If we saw the beginning of the log we could tell what the command was.
A timeout error doesn't return anything from their server so we can't draw any conclusions.
That said, Let's Debug does not timeout yet they still don't have a new certificate.
@youknowit2 Since your last good cert about 3 months ago have you added any kind of firewall?
We can see in the log that the Apache plugin was used.
That's an interesting observation. I'm glad you checked that. Maybe changes have been made since OP? :thinking:
Thanks for your replies. It has been fixed. The maintainer for korea.ac.kr domain recently changed their firewall policy. They have now been informed of the problem and modified their firewall policy to accept port 80 connection request from acme-v02.api.letsencrypt.org host. Now everything works fine.
