Renew: Timeout during connect
My domain is: martynkov.ru
I ran this command: sudo certbot renew
It produced this output: Timeout during connect (likely firewall problem)
My web server is (include version): nginx/1.24.0
The operating system my web server runs on is (include version): Ubuntu 24.04
My hosting provider, if applicable, is: selfhosted
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 5.1.0
Domain is accessible from 50/50 locations: Website Availability Test - Check Website Uptime | Uptimia
Check: martynkov.ru - Make your website better - DNS, redirects, mixed content, certificates
Then the fact it's not 100 % is likely the issue.
Certbot failed on secondary validation. In nginx access.log I see
23.178.112.107 - - [12/Oct/2025:13:03:39 +0000] "GET /.well-known/acme-challenge/hqtwk38SkBi6fF7B9og1UccohNROA3CzFptg6yO0AN0 HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
most of LE secondary challenges are from AWS: are you happen to block those?
Yes, I figured as much.
You should see 4 to 5 of those per challenge.
I don't block AWS special. But I try move firewall input rule on first place and clear block lists of bot. Unfortunately, the result remains unchanged.
A test from my own AWS test server fails. If it isn't just AWS you block then something is still blocking requests
curl -i -m7 http://martynkov.ru/.well-known/TestFromAWS
curl: (28) Connection timed out after 7000 milliseconds
Thanks for help! I was able to get the certificate after disabling Wireguard connect on my mikrotik router.
