Status: 404 Detail: No order for ID 848437233
My domain is: lssmv4.ledbrain.de
I ran this command: Tried adding via Plesk
Invalid response from https://acme-v02.api.letsencrypt.org/acme/order/62901597/848437233.
Details:
Type: urn:ietf:params:acme:error:malformed
Status: 404
My web server is: Apache
The operating system my web server runs on is: CentOS 7.6 64-Bit
My hosting provider, if applicable, is: Bitpalast®
I can login to a root shell on my machine (yes or no, or I don't know): Not as root.
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk
I also re-created the subdomain but It failed with exactly the same ID.
How can I solve this Issue?
Greetings Jan :slight_smile:
Try resolving this FQDN to an IP.
Try getting the cert being served to you by that link.
[show your findings]
Or maybe the Plesk panel just needs to be updated...
Hi @KBOE2
simple answer: That’s a Plesk bug.
Read
there is a bugfix. And update your Plesk.
Thanks for your help!
I’ll try to update Plesk and let you know wether it works then!
I would have never thought of the Problem being at Plesk :upside_down_face:
Greetings Jan
With the help of the provider, the Domain now has a valid certificate!
