My domain is: www.cold-steel.nl
I have used direct admin to install the let’s encrypt SSL.
It works fine, but this is a multistore (cold-steel.nl as main and coldsteel.be pointed to it)
I can get ww.cold-steel.nl to work, but the second url does not (www.coldsteel.be). It cannot confirm the .be.
A solution could be to add coldsteel.be to direct admin (so not only as a domain pointer), and add the ssl, but the problem is that i loose my website (multistore) that way on this domain.
Any ideas? Is it clear what i tell you guys?
Christophe Slegers
