SSL Lab shows my certificate chain is incomplete
My domain is: cdluk.kpmgonline.co.uk
brew install certbot
mkdir ~/lets-encrypt
certbot certonly --manual --key-type rsa -d --preferred-challenges=http --config-dir ~/lets-encrypt --work-dir ~/lets-encrypt --logs-dir ~/lets-encrypt
azure
azure
How did you install the certificate into "azure"?
I uploaded the full chain into azure key vault and used into app gateway listner
Using fullchain.pem should be enough :man_shrugging:t2:
Please wait for someone with (more) experience with Azure, as I don't have any clue why using fullchain.pem wouldn't work.. Or ask Azure :slight_smile:
I checked with azure support and they said there might be an issue with cert chain and i am getting unable to verify first cert error in postman if i am sending request by enabling SSL verification
Well, it sounds like you're not installing the full chain where it needs to go, then. But it also sounds like you're doing a lot of manual, error-prone steps. Can't you configure Azure to just get and install its own certificates and chains?
Yes, I can confirm cdluk.kpmgonline.co.uk:443 is only sending the end leaf certificate without any intermediates, so there indeed is a chain issue.
However, using fullchain.pem usually does the trick, but as I said, I have no experience with Azure, so as Peter says it might have something to do with how you need to upload the chain. Sometimes it's required to separately send cert.pem in one place and chain.pem in another field.
I also agree with Peter that it's best to automate things. But that also might be depending on what kind of Azure service you're using. :man_shrugging:t2:
How can i add intermediate cert to the bundle?
when i uploaded the full chain, it said it needed the private key so i added the private key as well to the full chain and uploaded. Is there a way you can help me complete the cert chain and i can try uplaoding that
The intermediate chain is present in fullchain.pem already.
How to fix this in Azure, I don't know.
I think you need to describe, step by step, exactly how you're getting the files that certbot produces into wherever you're trying to put them in Azure (and what that Azure interface looks like). (And again, it's likely that whatever those steps are can all be automated which will make things easier on you.)
I generated the certs using following steps :-1:
certbot certonly --manual --key-type rsa -d cdluk.kpmgonline.co.uk --preferred-challenges=http --config-dir ~/lets-encrypt --work-dir ~/lets-encrypt --logs-dir ~/lets-encrypt
After that it genrated these certs for me
README cert.pem chain.pem fullchain.pem pkcs12.pfx privkey.pem
In Azure ,
i am uploading cert to teh 443 listner
Certbot doesn't make a .pfx file in its output; where did that come from?
What you do mean by "cert" and "upload"? We're still not clear on what you're doing where that might not have the full chain.
PFX file was generated by me using openssl commands.
Sorry, for using shortcuts. I meant i uploaded the full chain certificate to the azure app gateway listner
So are you uploading that pfx into Azure? Because then that file probably doesn't have the full chain. How did you create it?
This is the command i used to export full chain to pfx
openssl pkcs12 -export -out yogitatest.pfx -inkey privkey.pem -in fullchain.pem
