Intermediate chain missing on Azure, please help
My domain is: loadbalancer.22dao.org
I ran this command: sudo certbot certonly --email contact@22dao.org -d loadbalancer.22dao.org --agree-tos --manual
It produced this output: a key, I converted it to a pfx and uploaded it as a certificate to an azure load balancer
The operating system my web server runs on is (include version): Azure gateway
Hello and welcome to the community @22dao
It fails to validate on some clients because you do not send any intermediate certificates (the chain). I do not know how to do that on Azure but this is why it is failing. Use a site like this to see the missing chain. Use this same site with a website like this one to see what it should look like.
https://decoder.link/sslchecker/loadbalancer.22dao.org/443
Hi Mike, thanks for the reply! How do I make sure I have the full chain?
This was the tutorial I used: Automating Azure Application Gateway SSL certificate renewals with Let’s Encrypt and Azure Automation (intelequia.com)
Down at the "Installing the Let’s Encrypt certificate by the first time on the Gateway" section
Did I lose part of it when I was converting the chain
I still don't know :slight_smile: I was hoping that was enough of a clue for you. Otherwise wait for an Azure expert to assist. I am going to change your title to signal that.
So I generated the certificates on a linux vm and then converted the pfx format using this conversation. Then I uploaded them to azure, so I think it has to do with the export/conversion process. Anything stand out?
This was the conversion command
sudo openssl pkcs12 -inkey <loadbalancer.pem path> -in <loadbalancer.cert path> -export -out loadbalancer.pfx
I think I fixed the problems with the SSL Checker (decoder.link)
but am still ruinning into some problems, any ideas??
Generate your PFX with the ISRG Root X1 chain (not the default DST Root CA X3 which is not really valid on windows). If using certbot use the fullchain.pem file for your cert (this includes the intermediates). You also need to set a PFX password for it to be used on Azure.
If you can use Azure Key vault you can automated this with https://certifytheweb.com (the app I develop) - with that you would generate a certificate with a password (set under Certificate > Advanced > Signing & Security) and add a Deploy To Azure Key Vault task, then configure your gateway to pickup it's cert from Key Vault (if possible). That way, subsequent automatic renewals will push the new cert to key vault and keep the cert up to date (I think! I haven't tried Azure Gateway).
Is this what you mean by using the fullchain.pem file as the cert? or should should it be used as the -in file?
sudo openssl pkcs12 -inkey /etc/letsencrypt/live/loadbalancer.22dao.org/privkey.pem -in /etc/letsencrypt/live/loadbalancer.22dao.org/cert.pem --certfile /etc/letsencrypt/live/loadbalancer.22dao.org/fullchain.pem -export -out ~/loadbalancer.22dao.org.pfx
Try:
sudo openssl pkcs12 -export \
 -in    /etc/letsencrypt/live/loadbalancer.22dao.org/fullchain.pem \
 -inkey /etc/letsencrypt/live/loadbalancer.22dao.org/privkey.pem \
Perfect, thanks!! This fixed it :slight_smile:
