SSL Issues with Safari Only?
My domain is: www.heartstartnj.com
My web server is (include version): Apache Version 2.4.46
The operating system my web server runs on is (include version): Linux - 3.10.0-962.3.2.lve1.5.38.el7.x86_64
My hosting provider, if applicable, is: inmotionhosting
I can login to a root shell on my machine (yes or no, or I don't know): No
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, cpanel 86.0
Having issues with my SSL. I have the paid version of the Lets Encypt installer. Everything seems to be installed correctly - except that on IOS devices using safari they're getting a 'Connection is not private' error. Everywhere else is working fine, on chrome or firefox. No problems.
Hi @Heartstartnj
that's wrong, I see the same problem with FireFox. Your www version has the wrong certificate - see https://check-your-website.server-daten.de/?q=heartstartnj.com#url-checks
β€’ http://heartstartnj.com/ 104.244.120.9 301 https://heartstartnj.com/wp-content/endurance-page-cache/_index.html
Html is minified: 100,00 % 0.320 A
β€’ http://www.heartstartnj.com/ 104.244.120.9 301 https://www.heartstartnj.com/wp-content/endurance-page-cache/_index.html
Html is minified: 100,00 % 0.317 A
β€’ https://heartstartnj.com/ 104.244.120.9 GZip used - 13453 / 57815 - 76,73 % Inline-JavaScript (βˆ‘/total): 15/3230 Inline-CSS (βˆ‘/total): 7/18763 200 Html is minified: 169,20 % 5.493 B
β€’ https://www.heartstartnj.com/ 104.244.120.9 GZip used - 13453 / 57815 - 76,73 % Inline-JavaScript (βˆ‘/total): 15/3230 Inline-CSS (βˆ‘/total): 7/18763 200 Html is minified: 169,20 % 5.277 N
Certificate error: RemoteCertificateNameMismatch
Your certificate
CN=heartstartnj.com
	13.01.2021
	13.04.2021
expires in 48 days	heartstartnj.com - 1 entry
has only one domain name, so your www version isn't secure.
And your browser may has cached the redirect, so you don't see that with some browsers.
Create one certificate with both domain names.
Alrighty! I deleted the old certificate and reinstalled it.
Hopefully that fixes everything.
Use online tools or something like curl to check that.
Then fix the other / minor problems -> www has a curious redirect, both https versions (non-www and www) with a http status 200, that's duplicated content.
