Safari users get "Connection is not Private" error
Safari users sometimes get "Connection is not Private" error when accessing my site (which uses NGinX and Let's Entcrypt).
My domain is: s4w.paylex.com
My web server is (include version): OpenSSL-based APP
The operating system my web server runs on is (include version): Windows Server 2012
My hosting provider, if applicable, is: AWS
You are sending the leaf certificate alone. You need to send the intermediate(s) as well. If you use certbot and your app supports it, send fullchain.pem. If you have to use cert.pem, then you have to use chain.pem as well.
https://www.ssllabs.com/ssltest/analyze.html?d=s4w.paylex.com&hideResults=on&latest
I was able to improve the configuration, as per your suggestion, and am now getting a better result on ssllabs. Hopefully this will also resolve the issue with Safari browsers, Thank you so much.
You should check again. I am seeing only a leaf sent by your server for s4w.paylex.com
There is still no cert chain sent.
If you show us results of this command we could describe what is wrong:
sudo nginx -T
your certificate chain is still incomplete. safari doesn't like that.
I have a test server hosting t4.paylex.com and t4w.paylex.com. This seems to be working properly.
The difference in the configurations involves the Alternative Name, which has both names in the case of t4.
Would like to create that same result, but not sure how to get WinAcme Windows to add both Alternative names to the cert.
We activated both sites simultaneously in IIS before launching LetsEncrypt (via WinAcme 2.1). This achieved the goal, both sites added to the Subject Alternative Name (SAN) List.
Thank you all!
