I’ve installed cyberpanel which automatically generates ssl certificate for hosted websites via let’s encrypt.
The issue is, whenever i try issuing ssl certificate for the domain it gives an error “rate limits exceeded”, I’ve read this : https://letsencrypt.org/docs/rate-limits/ & i don’t know how much time do i exactly need to wait so that i can generate a new one.
Any help regarding this would be very appreciated, i need to fix it ASAP.
Cannot issue SSL. Error message: [Thu May 23 01:44:32 UTC 2019] www.heyheyhey.com:Verify error:dns :: DNS problem: NXDOMAIN looking up A for www.heyheyhey.com [Thu May 23 01:44:32 UTC 2019] Please add ‘–debug’ or ‘–log’ to check more details. [Thu May 23 01:44:32 UTC 2019] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh [Thu May 23 01:44:34 UTC 2019] Create new order error. Le_OrderFinalize not found. { “type”: “urn:ietf:params:acme:error:rateLimited”, “detail”: “Error creating new order :: too many certificates already issued for exact set of domains: heyheyhey.com: see https://letsencrypt.org/docs/rate-limits/”, “status”: 429 } [Thu May 23 01:44:34 UTC 2019] Please add ‘–debug’ or ‘–log’ to check more details. [Thu May 23 01:44:34 UTC 2019] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh 0,283 Failed to obtain SSL for domain. [issueSSLForDomain]
Visible Content: 301 Moved Permanently The document has been permanently moved to here . Proudly powered by LiteSpeed Web Server Please be advised that LiteSpeed Technologies Inc. is not a web hosting company and, as such, has no control over content found on this site.
