It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] cannot load certificate "/etc/letsencrypt/live/giveway.ozonechain.io/fullchain.pem": BIO_new_file() failed (SSL: error:80000002:system library::No such file or directory:calling fopen(/etc/letsencrypt/live/giveway.ozonechain.io/fullchain.pem, r) error:10000080:BIO routines::no such file)
nginx: configuration file /etc/nginx/nginx.conf test failed
The nginx plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError('Error while running nginx -c /etc/nginx/nginx.conf -t.\n\nnginx: [emerg] cannot load certificate "/etc/letsencrypt/live/giveway.ozonechain.io/fullchain.pem": BIO_new_file() failed (SSL: error:80000002:system library::No such file or directory:calling fopen(/etc/letsencrypt/live/giveway.ozonechain.io/fullchain.pem, r) error:10000080:BIO routines::no such file)\nnginx: configuration file /etc/nginx/nginx.conf test failed\n')
My web server is (include version):nginx
My hosting provider, if applicable, is:yes
Then you've deleted a previously issued certificate without removing said certificate from your nginx configuration, thus breaking said nginx configuration, as expected.
i generated ssl certificates
its present in /etc/letsencrypt/live
but nginx is not active with error cannot load certificate "/etc/letsencrypt/live/giveway.ozonechain.io/fullchain.p>
listen 80;
server_name giveway.ozonechain.io;
