Ssl certificate issue
My domain is:app.public.crsquare.finance
I ran this command:salt minion name state.apply letsencrypt
It produced this output: Error while running nginx -c /etc/nginx/nginx.conf -t.
              nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/app.public.crsquare.finance/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/app.public.crsquare.finance/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
              nginx: configuration file /etc/nginx/nginx.conf test failed
              The nginx plugin is not working; there may be problems with your existing configuration.
              The error was: MisconfigurationError('Error while running nginx -c /etc/nginx/nginx.conf -t.\n\nnginx: [emerg] BIO_new_file("/etc/letsencrypt/live/app.public.crsquare.finance/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen(\'/etc/letsencrypt/live/app.public.crsquare.finance/fullchain.pem\',\'r\') error:2006D080:BIO routines:BIO_new_file:no such file)\nnginx: configuration file /etc/nginx/nginx.conf test failed\n')
The operating system my web server runs on is (include version):debian
My hosting provider, if applicable, is:aws
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 0.31.0
I see you got a cert since you posted. And, your nginx server is sending it out.
Do you still need help?
Done, Thank you so much.
