squarespace
no
squarespace
I have seen from some of the other posts in this forum that squarespace has issues issuing (heh) certificates from time to time. I was just hoping that you could tell me if there is currently a technical issue issuing this cert, or if it’s truly dns cache time.
This would be a matter directly related to squarespace, as they are responsible for requesting / installing / renewing your certificate.
Currently, there aren't any issue related to Let's Encrypt Service, and only squarespace would know if they have any issue with their automation.
Hi @wulfmann, sorry to hear you're having troubles.
I'm only aware of one specific problem related to mit.edu rate limiting. If you're having trouble with a different domain with Squarespace I'd second @stevenzhu's suggestion (thanks!) that you contact Squarespace support. They would need to provide more information about what the delays are. There aren't any ongoing issues on the Let's Encrypt side.
