SLL is Installed, but Not Working?
Originally installed through openlitespeed from the GCP Marketplace.
Recently tried to follow instructions for CertBot, and get good indications that the SSL certificates have been installed, but the expiry headers are set to today, so it’s not working properly, and the dry runs, for auto-renew, are failing.
Tired of jacking with this crap every 6-months, and thought Litespeed would know better, and have this pre-configured.
openlitespeed
Ubuntu 18.04
Google Cloud Platform (GCP)
Yup
Nope
certbot 0.31.0
Expiry looks fine to me.
$ openssl s_client -connect www.getivan.com:443 -showcerts 2>/dev/null | openssl x509 -noout -subject -issuer -dates
subject=CN = www.getivan.com
issuer=C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
notBefore=Oct 19 18:49:56 2019 GMT
notAfter=Jan 17 18:49:56 2020 GMT
If you are checking inside your browser, they can be pretty lazy about showing new SSL information unless you close and re-open the tab.
What's the error?
Hey, AZ, thanks for replying so quickly.
Yeah, I literally just discovered it was working, right after I submitted this post.
You were correct about opening new tabs.
I was refreshing, and clearing browser cache, but none of that worked.
Only discovered it, because someone mentioned it looked fine, and I opened it up in another Firefox browser, to see.
The Auto-Renew is still not working, though.
Tried this:
sudo certbot renew --dry-run
Threw this error:
> Cert not due for renewal, but simulating renewal for dry run
http-01 challenge for getivan.com
http-01 challenge for www.getivan.com
Attempting to renew cert (www.getivan.com) from /etc/letsencrypt/renewal/www.getivan.com.conf
produced an unexpected error: Missing command line flag or config entry for this setting:
Input the webroot for getivan.com:. Skipping.
/etc/letsencrypt/live/getivan.com/fullchain.pem (failure)
/etc/letsencrypt/live/www.getivan.com/fullchain.pem (failure)
:grimacing:
Can you post the contents of /etc/letsencrypt/renewal/www.getivan.com.conf? (Normally none of it is sensitive.)
How recently did you start using Certbot?
https://crt.sh/?q=getivan.com
It looks like certificates have been successfully issued every ~60 days since 2017, with a few extra ones at various points.
There was even one issued on the normal schedule a month ago.
