SLL creating problem
Ошибка: Не удалось создать SSL/TLS-сертификат Let’s Encrypt для sb-remont.kz . Не удалось выполнить авторизацию для домена.
Подробнее
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/2430828335.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.sb-remont.kz
Hi @pharell
please answer all of the following questions:
There is a check of your domain - https://check-your-website.server-daten.de/?q=sb-remont.kz#txt
But there
Domainname TXT Entry Status ∑ Queries ∑ Timeout
sb-remont.kz v=spf1 +a +mx -all ok 1 0
www.sb-remont.kz v=spf1 +a +mx -all ok 1 0
_acme-challenge.sb-remont.kz Name Error - The domain name does not exist 1 0
_acme-challenge.www.sb-remont.kz Name Error - The domain name does not exist 1 0
is no TXT record visible.
Without the details of your client / command it’s impossible to find a solution.
