Hi, I just ran certbot and now my site is unreachable. no http and not https. it just doesnt load, no direct error message.
My domain is: test.designing-history.world
1: test.designing-history.world
blank to select all options shown (Enter ‘c’ to cancel):
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/test.designing-history.world.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/drupal-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Congratulations! You have successfully enabled
https://test.designing-history.world
https://www.ssllabs.com/ssltest/analyze.html?d=test.designing-history.world
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/test.designing-history.world/fullchain.pem
/etc/letsencrypt/live/test.designing-history.world/privkey.pem
Your cert will expire on 2020-04-22. To obtain a new or tweaked
with the “certonly” option. To non-interactively renew all of
your certificates, run “certbot renew” -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My web server is (include version): apache2
The operating system my web server runs on is (include version): Debian 9 stretch
My hosting provider, if applicable, is: hosteurope
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
